Sony MEX-BT3900U continuous reset
Hye,
I had bought 2 audio cd-players, I`ve connected one (an Sny Mex-bt3900u) in a 1996 Daewoo Cielo, using an ISO adaptor, and another one (a Sony CDX-230) in a 2004 Citroen Berlingo. In either cases i`ve started them, but after  i set them up i have the problem of reseting. Agter some time, they reset themselfs to factory settings, sometimes after a quarter- half an hour. How do i work it out? It`s not like i have problems with only one, it`s the same problem with both of them!
1 REPLY 1
Anonymous
Not applicable
Hi there
It is interesting that you have the same fault on two different model CD Players and cars.  Therefore I would assume there is a wiring issue somewhere.
For the BT3900U : Manual HERE
Especially trace the circuit for whether its connect to the cars battery - as this should be the one that prevents resetting (i.e. disconnect car battery resets the unit - but with a continuous power supply, it should be ok)
Cheers
