Problems with television screen
SOLVED
profile.country.en_GB.title
nannym
Visitor
My older television (bought December 2006) KDL-32s2030 has been working fine until yesterday. There is now a block of multi-coloured stripes down the centre of the screen and a few horizontal lines on the top.
Grateful if anyone has any ideas.  Is my television on the way out!  or would it be worth getting it repaired?
Many thanks for any help.
nannym
1 ACCEPTED SOLUTION
Accepted Solutions
Bravia55HX
Member
Hi,
this is becomming common on many earlier panels now and this will get progressively worst the only solution next to purchasing a new tv is a replacement panel and this is quite expensive  to replace.
2 REPLIES 2
Bravia55HX
Member
Hi,
nannym
Visitor
Hi
Many thanks, I guess I knew that would be the case but thought I would ask.
