KDL-40EX520 - how do I get additional widgets
profile.country.en_GB.title
Andrew1234567
Visitor
I have just purchased the KDL-40EX520 and currently on tv it is only possible to see the Facebook and Twitter widgets.  Per the manual there seem to a lot of available widgets but I cannot find any way to update the list on the TV.  My TV is connected to the internet and I have updated the software, etc.  Can anyone help?
A second issue I am having is that I have also tried to connect a computer to the TV.  Unfortunately the computer does not have an HDMI socket so I have had to do this via the VGA socket with an extra cable from the headphone socket to the Red/White plugs on the back.  However, I do not seem to be able to get any sound when I do this.  I have a second computer with an HDMI socket and when I use this there is no problem getting sound through the TV.  Does anyone know what the problem with the first computer may be?
Thanks in advance for any help.
Message was edited by: Andrew1234567
1 REPLY 1
TheLegendofZorro
Visitor
I was on here looking for info on additional widgets myself, so I'm unable to help yo on that question.
For the audio issue you have, below the PC connector ( VGA input) on the TV you will see a similar socket to the headphone output on your laptop, you can connect using a 3.5mm to 3.5mm stereo jack audio cable. The sockets I think you are using are for the AV2/Component input.
Hope this helps.
