Freeview probs on a KD-32DX40U.
SOLVED
profile.country.en_GB.title
posybear
Visitor
Has anyone else experienced problems receiving some Freeview chanels on a KD-32DX40U ?
1 ACCEPTED SOLUTION
Accepted Solutions
Catmambo
Contributor
Hi
You may have the 'Split Nit' issue.
http://www.digitaluk.co.uk/Split_NIT_24_Nov_11.pdf
Please contact the support centre directly and mention this may be the issue and thy can advise on the current procedure.
Thanks
1 REPLY 1
Catmambo
Contributor
Hi
Thanks
