Brightness of menu screens
profile.country.en_GB.title
grahamdeepwell
Visitor
For example, Input. My Bravia TV is in the conservatory, so it is very bright during the day.
I have everything full up for the picture, but if I want to change the input device, I can hardly see it.
Tags (1)
2 REPLIES 2
KDL-CX520
Visitor
Hello and welcome to Sony forums
Because your TV used in the conservatory , I suggest you to reset your new TV to SHOP MODE
this will give you the max. brightness for picture and menu screens too
Depend on which model you have, go to menu screen and look for FACTORY reset / FACTORY setting or AUTO START- UP
Hope this will help
Regards
Bravia55HX
Member
Hi,
better still, if you must have the tv there, get some blinds put up!,
