STR DN1060 AV Receiver - Google Cast Sound Field Issues
jojawha
Explorer
Hi,
Does anyone else have issues with choosing a Sound Field when using Google Cast. Player won't let me choose any mode other than A.F.D (if you click on any other mode it says NOT.USE on the receiver's display). There is no output to my Subwoofer either (this is only in Google Cast mode). With any other music source the receiver outputs low frequencies to my Subwoofer in A.F.D.
This has only been happening ever since the recent firmware update on 14.09.2016 (M29.R.0422)
104 REPLIES 104
thenumptee
Explorer
I know what you mean. When I said small thing,  I meant from a technical point of view.
Anyway, I've sent the email so we'll see if they respond and I'll post the response here if they do.
thenumptee
Explorer
So I've had a reply already but it's not of any real help:
Thank you contacting Sony support.
With reference to your inquiry, we are sorry to learn that you're unable to use the Subwoofer on the built-in Chromecast.
We are currently investigating this matter further and we will update you as soon as possible.
I guess if enough people contact them then maybe they'll take it seriously and get a fix rolled out.
thenumptee
Explorer
I've received another email from customer service and I'm stunned:
With reference to your inquiry, we are very sorry to inform you that the subwoofer is not supported on the built-in Chromecast on this  model.
We apologies for any inconvenience.
I don't actually have any words at the moment. 😠
profile.country.EE.title
Searching81
Explorer
Yup, pack of useless pricks.
Darbo25
Member
Beggars belief doesn't it?
"your receiver doesn't support this feature".
It bloody did when I bought it sunshine,  and I'm not sure you can call it a feature...it's more of a basic function.
