In ear music volume
SOLVED
lukew1985
Visitor
In ear music volume
Seems to be very low. This is my only negative with this phone.
Have a tried and tested different settings and headsets and I'm quite disappointed with it.
Headsets used are - soundmagic e10s, beats in ear, the headset from the box, and my HTC sport in ear.
Anyone else thought the same? Hopefully it's a software limitation that can be altered. Also the handset speaker volume is decent, can't complain about that.
1 ACCEPTED SOLUTION
Accepted Solutions
Lord_viridis
Alrite LukeW
What settings you got turned on in (settings, sounds & notification, audio settings)
Turn on dynamic normalise leave the others off.
In sound effects, change your equaliser to shape the sound.
Also go in (accessory settings) and turn on auto optimisation
4 REPLIES 4
profile.country.US.title
Qatrium
@lukew1985
Would you try to clear cache from your Smart Connect app:
- Go to Settings -> Apps -> Smart Connect -> Force stop, Unistall updates, Clear data and restart your phone.
- Go to your Play Store and update Smart Connect again.
lukew1985
Visitor
OK that app wasn't installed so I have done and will see if it's different
Cheers
Lord_viridis
Alrite LukeW
lukew1985
Visitor
Cheers viridis (from o2 forum too?)
That seems to be much better. Will test fully tomorrow
Thanks
