NWZ-A10
bufff69
New
NWZ-A10
Hi does this have LDAC (from an update I believe) and can it play DSD files also would this be better than my S7 Edge and USB dac as using my phone uses a lot of battery. I will be using it with an MDR1000x so LDAC would be great when using Bluetooth many thanks bufff69
1 REPLY 1
Sonyvores
Contributor
Walkman A10 needs latest firmware update to have LDAC capability.
For that price you won't have DSD playback (your S7 can't either) you need to go with ZX1/ZX2 or Xperia phones to have DSD playback
As a standard music player it will be alraedy much better than your S7 Edge so it will be an upgrade. 😃
