XL202 5.1 channel problem
dclmun
Visitor
hello everybody,
I got a problem. I don't know how to setup 5.1 channel for my xl202.
can anybody teach me how to do so?
my 5.1 channel is NOT come with HDMI..........
Many thanks
1 REPLY 1
h4
Visitor
hi
i have a 301 but it should be the same. you'll need to connect your 302 to your sound system osing the toshlink connector or the coaxial, depending on which your sound sytem has. its simply a wire between the two and it shoukd work as long as you have enable sound devices to hdmi and spdif on your 302.
