Wireless Connection
bascom
Visitor
Wireless Connection
Just purchased a vaio vgn-a195hp and it cannot detect my Linksys wirless network. Presently run Dell Laptop and US Robotics Card in workstation so network is fine. Any ideas?
2 REPLIES 2
grahambird80
Visitor
Just a thought but you have turned the wireless card on?
streetworker
Visitor
good morning! .. good "thought" .. I DIDN´T at the very beginning, searching for everything else first :smileygrin: ; by the way .. my wireless unit is deactivating itsself periodically (5 minutes appr.), interrupting lan connection .. any idea about that? would be very greatful for any hints .. :thinking:
psae.: vaio type is PCG-K215Z, access point d-link router DI-714P+
psae2.:
"Solution A01048
Description:
When I connect to the Wireless LAN, it disconnects after a few minutes - I have installed the Windows XP Service Pack 1 on my VAIO computer.
Solution:
When connecting to the Wireless LAN, clear the check box in front of the option Enable IEEE 802.1x authentication for this network."
.. it IS checked!
