Where can i get Replacement DVD/CDRW for PCG FX505
Tracie
Visitor
Hi there:smileygrin:
I have a FX505 who DVD player part of the DVD/CDRW has given up the ghost! Any ideas on how i can get it replaced with a DVD/DVDRW drive???
Any help gratefully received!
Ta Tracie:smileyblush:
6 REPLIES 6
profile.country.en_GB.title
tellingd
Visitor
Try here
HTH
Tracie
Visitor
Dave
Many thanks for that! Do you know of anywhere in the UK that does them or do i have to buy from US?
Ta
Tracie
tellingd
Visitor
Unfortunately no I don't - but there shouldn't be any problem buying from the US site, unless you want it shipped to Iraq :wink:
kee-lo_
Member
Yeah I can see your problem, specially if you only have Miestro :cry:
JoeB.
Visitor
hi,
in germany there is a company that can get you just about any part for a notebook that you need.
http://www.polaris-sabel.de
ask them before you buy in the US. it could be cheaper
Joe
JoeB.
Visitor
P.S. save the front panel of the broken drive... then maybe you could find a slimeline at ebay and change the panel... a lot slimline drives are the same make....
Joe
