Hi there. As of today my VGN-FZ21M is not booting. When i press the power button the small power light comes on and a small click can be heard from the hard drive but other than that nothing else is happening. The actions i took were the following:
1. I took off the ram sticks switched em, tried with each one by itself. No results. I plugged the ram sticks in another machine and it seems that one is faulty and the other is ok. I plugged in the good one with no results, switched slots and still had no results.
2. I tried using an external monitor. No results also.
3. I opened the laptop remove the bios battery plug, wait for some and plugged it again with no results.
4. The battery is charging so i dont think there is a power issue. i double checked every ribbon on the board and everything seems to be in good order.
5. I fear it is the mobo.
Anyone has any suggestions??
Unfortunately it sounds like you may be victim of the common motherboard/gpu fault with the VGN-FZxxx range. (only my opinion based on symptoms / what you've tried)
There are a number of options...
Replace the motherboard - model: A1369749A MBX-165
Best price I have found is £145.00 (however you will need to have it fitted if you are not able to do it yourself) and that was on eBay ( http://cgi.ebay.co.uk/LAPTOP-SONY-VGN-FZ21M-A1369749A-MBX-165-MOTHERBOARD-/120685621732?pt=UK_Comput... )
Find a repair shop which will do the repair for you... again, prices vary and services vary:
From £10.00 to diagnose and ship back if you don't want the repair, quote on inspection:
From £63.00 including return shipment for dignose and repair
Hope this helps, let us know how you got on!
You may also qualify for a free repair under the extended warranty that sony have provided due to the recognised mobo/graphic failure in the FZxxx series!!
Look at this post:
