I recently installed Internet Explorer 9 by mistake - thinking it was a normal update, not realising that it was just a beta version - I didn't like it and went through the procedure of uninstalling the update in order to get back to IE8. Ever since then I've had problems.
If I start IE8, then my Windows Live Mail won't connect to my servers to download mail. If I start the mail program first and download my mail then IE8 won't load any webpages just keeps showing trying to connect. My internet connection is fine - only problems with these applciations.
Any ideas why and any solutions?
Thanks!
Not alone with this problem.
Try removing IE8 and re-installing it:
Step 1: To uninstall Internet Explorer 8, follow these steps:
Step 2: Re-Install IE8
Let me know how you get on!
