vgn-fs215b problem with hotkeys
trelka
Visitor
Hi.
I've a problem after complete reinstalling my vaio (format c: etc). I've installed win xp pro and all of the hardware. The only thing i found out that doesn't work is hotkeys (like Fn+f4 for volume, S1, S2 etc.) and i don't have a clue what to do with it. I went to vaio support site but i couldn't find any manual about how to deal with it. I've installed all drivers from the original website, but it doesn't work. Could anyone help me with this?
Thank You
5 REPLIES 5
rich912
Contributor
Hi trelka and welcome to the forum.
Download the pre-installed utilities for your model from Vaio Link and extract the file. Then install the following in this order:
1 Sony Utilities (Installer Folder 1)
2 Sony Shared Library (Installer Folder 2)
3 Vaio Event Services (Installer Folder 7)
Then re-boot.
You may find that you need to repeat this process a couple times before the hotkeys work.
Go n-éirí an bóthar leat
trelka
Visitor
Hello everyonejavascript:smilie(':smileyhappy:')
Rich912 thank You for that
rich912
Contributor
You're welcome trelka:smileyhappy:
Thanks from me too, I was having the same problem.
Charlie.
rich912
Contributor
Pleased to hear that this also solved your prolem Charlie.:smileyhappy:
