Vaio VGN-FZ21Z won't go into standby.
clyarwo
New
For some reason I can no longer get my Vaio to sleep. I choose the option in the start menu and the screen goes blank but thats all. Everything is still running in the background and if I move the mouse then the screen wakes up.
It used to work when I had just rebuilt it but for some reason it has now stopped. Hibernation is also not working with the same symptoms. Can anyone help please?
1 REPLY 1
Thalamus.
Champion
Hi Chandler,
have you installed any updates or applications recently.?
At a guess I suspect a running application or process is causing your Vaio to hang on sleep/hibernate..
This could be long winded but try stopping an application or process vai Task Manager and then see if your Vaio enter sleep mode correctly.. :thinking:
