VAIO VGC-V3S clear/reset CMOS
Divine3000
Visitor
How do I clear CMOS on my VGC-V3S? I have installed 2 new RAM modules which should be acceptable but are causing intermittent boot problems.
Thanks'
4 REPLIES 4
Blencogo
Why do you think there is a problem with the CMOS? Are the memory modules not recognised?
What is the specifications of the memory modules you have installed?
:thinking:
Divine3000
Visitor
:thinking:
Yeah the memory modules seem to work fine, but the PC has to be switched On-Off-On in order to boot up. When it is first powered up it doesn't reach BIOS stage without being switched back off/on via the mains.
This problem has only begun since the modules were installed, I read resetting the CMOS has fixed similar problems.
Crucial 2X 1GB, 184-pin DIMM, DDR PC3200 memory modules
CT521307
Module Size: 1GB
Package: 184-pin DIMM
Feature: DDR PC3200
Specs: DDR PC3200 • CL=3 • Unbuffered • NON-ECC • DDR400 • 2.6V • 128Meg x 64 •
Thalamus.
Champion
Hi Divine3000,
could the problem be due to the fact that you've installed more than the maximum supported 1GB or RAM.. :thinking:
Divine3000
Visitor
Hi Divine3000,
Hi Thalamus,
This is a definite possibility, although according to Crucial the PC supports 2gb. I guess I'll remove a module and see how it fares. I did read similar threads to this suggesting that the CMOS is still trying to use the original 512mb RAM & clearing it would fix the issue.
Thanks' for your input guys :slight_smile:
