T1XP keeps freezing
FranzH
Visitor
T1XP keeps freezing
Hi,
Very recently, well in the past few hours, my vaio keep on freezing up. Im having trouble getting to the desktop because it just freezes while loading can anyone help me try and resolve this please?
Thanks
27 REPLIES 27
Blencogo
My laptop dosent have the panel at the bottom as it is te VGN-T series
Sorry Franz - my mistake.
We are back to square one I'm afraid.
:smileythinking:
FranzH
Visitor
Hmm, its ok. Ill keep searching around and reading things and see if i can dig up anything :slight_smile:
Thanks
FranzH
Visitor
I keep on getting the blue screen that says:
A problem has been detected and windows has been shut down to prevent damage...
DRIVER_IRQL_NOT_LESS_OR_EQUAL
If this is teh first time youve seen this Stop error...
Then it goes on to say:
Technical Information:
*** stop:0x000000D1
(0x0000000D, 0x00000000, 0xF87c2cc2)
*** PCIIDEX.SYS - Address F87c3cc2 base at F87C 3000, Date stamp 41107b4c
I have no idea what that means but i put it jus tincase someone knows.
If anyone can help i would really really appreciate it, thank you
rich912
Contributor
Hi FranzH,
Clutching at straws here but is
THIS of any help?
Go n-éirí an bóthar leat
FranzH
Visitor
Ill give it a try and hope for the best. Thanks :slight_smile:
Blencogo
PCIIDEX.SYS is a PCI IDE Bus Driver Extension and is one of the drivers for your ATA Storage Controller.
Either the Driver is corrupt or it is trying to use an impossibly high IRQL. It could also indicate a hard drive problem as the stop error is caused by the hard disc controller.
Go to Device Manager and expand the "IDE ATA/ATAPI controllers".
Double Click on the ATA Storage Controller (on my computer this is an 'Intel(R) 8280' device).
Select 'Driver'>Details and check that PCIIDEX.SYS is being used.
Uninstall the driver and reboot.
If this doesn't work you may have to install a different version of the driver manually as the PCIIDEX.SYS in your System32 directory may be buggered. Search in C:\Windows\i386\SP2.CAB although I think it is available in several different places.
Good Luck
:wink:
FranzH
Visitor
Ok, just need to get it to stay on with out freezing now :tongue:
Thanks alot :slight_smile:
FranzH
Visitor
Done it...
I uninstalled it as you said and then rebooted and turned it back on with no problems.
Is this all i need to do? :slight_smile:
Thanks
Blencogo
Let's hope so Franz,
I hope you had an IRQ conflict and reinstalling the driver has allocated a new IRQ ..............
.................... but if you continue to get problems we are back to looking for a poor connection - possibly between your Main Board and your Hard Drive or inside your Hard Drive.
Fingers Crossed !!!
:pray:
FranzH
Visitor
Well it sceems to work better and not freezae as much, but still, if i move the screen the pink likes appear and it freezes.
I got files i needed off it just incase so on the data side, im allright.
