Sreen Resolution (20 € for help)
condorwave
Visitor
Hello,
I need your help. I've got the Sony Vaio VGN-FZ38M and it worked very good together over a HDMI cable with my 24'' Monitor (Benq 2400W). In the past I had the possibility to switch to 1920x1200. But now I have only the possibility to switch to 1024x768. Has anybody an idea? I already install Vista one more time and install the newest NVidia 8400M GT drivers.
2 REPLIES 2
profile.country.pt_PT.title
luisarn
Explorer
Go to BENQ website and check if there's a driver available for your monitor. :slight_smile:
profile.country.en_GB.title
kee-lo_
Member
I have this monitor, it's superb
All you need to do is lower the resolution on monitor 1, and then you should be able to see the full size on the BenQ.
BTW the drivers you need are on the CD you got with it.
