sony vaio won't start
9jaoracle
New
when power on LED light is ON but the fan does not spin and the screen remain blank. i need urgent help on this
2 REPLIES 2
Blencogo
Hi 9jaoracle and welcome.
Please give us your Vaio Model which may allow someone to help you as some models have known problems.
Are you using the original OS and does this happen when you are using both AC and battery power?
sgdavies
Member
Try a "HARD" boot, by holding down the power button. ( for about 5 to 10 sec) to see if you get a response, or if don't work if you have an assist button try that, failing that try to see if you can get into the BIOS.
