Can I get/purchase recovery media for sony SVE1113M1EP
SOLVED
I need to reinstall SVE1113M1EP and the recovery partion is broken. Can I purchase recovery media from sony? What other options do I have?
1 ACCEPTED SOLUTION
Accepted Solutions
Nobody-in-particular
Contributor
Hi, if you can explain what issues you are having then maybe one of the Experts may be able to suggest other options but to answer your question yes you can purchase a set of recovery media direct from Vaio support. Click support at the top of this page, enter your VAIO model to locate support.
1 REPLY 1
Contributor
