I am just about to receive a little USED VGN-SZ650N/C with Vista business installed and
Laptop has one drive - a C drive.( 160GB) .
REQUIREMENTS: I would like to make changes so that my VAIO has :
5 Partitions including a recovery partition as is normal for a VAIO + XP ( as my current one )
- C drive - VISTA + all other laptop SW
- D drive - for potential install of XP if VISTA shows so impossible as many says
- E drive - my personal data
- F drive - for the use with Internet music + TV etc
- Drive for VISTA recovery partition
QUESTION
1) What actions in order of implementation do I need to take to make this happen ?
2) How do I produce a recovery DVD for – preinstalled SW including VISTA ?
3) Can VISTA and if what function can I use to create the 5 partitions ?
CONCERNS
1) Does VISTA installed on a VAIO provide the same facility as XP to produce a recovery DVD ?
2) When I try to partition the hard drive (160GB) into 5 partitions will I lose the recovery partition?
3) How do I find the Vista unlock key from the system if this is not provided by seller
4) What else do I need to do or ask the seller for ?
Any help would be much appreciated
Hans
Hi Hansc,
