Problems with sound and playing music
Nat1986
Visitor
Hello,
I've noticed recently, like in the last few days, that my vaio occasionally has problems with sound - I start it up and there will be no sound and nothing will play in iTunes. If I restart, this usually goes away, but obviously I would like to fix the problem!
Does anyone have any ideas?
Thanx a lot!
Model: FZ38M
Windows Vista
5 REPLIES 5
Thalamus.
Champion
Hi Nat1986,
have you installed or uninstalled anything before your sound problems started.?
Have you tried a system restore to a point before your sound problems started.?
I have attached a guide on system Restore should you need it, use the following link to view: Vista System Restore
Nat1986
Visitor
I did a Vaio update recently, I can't remember if it was before or after the problem started, it might well have been before. Could it be a driver issue? Also, I did all the automatic updates however it downloaded a few updates that I was required to manually install but didn't have the time to do so I left them, is that sometimes a problem? Where would these files have been downloaded to because I didn't take note of where they were.
Thanx
Thalamus.
Champion
Hi Nat1986,
did a system restore to a point before the you noticed the audio problem help?
It could be a driver issue, have you tried reinstalling your audio drivers.?
Not normally, unless the update states that it would solve a current problem with your Vaio..
Normally the updates that require manual installation are downloaded to the C:\Update folder..
Nat1986
Visitor
Hi,
the problem sorted itself out...hasn't arisen in last 4 weeks at least...it was probably a driver issue that was resolved with an update or something, cheers for help anyway!
Thalamus.
Champion
You're welcome Nat1986.. :slight_smile:
