No such thing as a pcg-7413m?
profile.country.en_GB.title
editorbeemac
Visitor
My pcg-7134m only has a very skimpy Quick Set-Up Guide but I could do with a comprehensive user manual. I have got nowhere on Google, except plenty of false leads, so I tried this Sony site. It seems that, according to Sony, there is no such thing as a PCG-7134M as all my searches say 'No results found for this search '.
Well, I know it does exist, even if Sony doesn't, so is there anyone who can help me find a user manual for it please?
4 REPLIES 4
editorbeemac
Visitor
PS. I know I put 7413 in the heading, but my searches were correct for pcg-7134M.
rich912
Contributor
The reason that you have no result for PCG-7134M on the Support site is that you are using the chassis number not the model number. I think that you will find that your model is VGN-NR32*/* which you should find on the bottom right of the screen surround.
Go n-éirí an bóthar leat
editorbeemac
Visitor
Thanks, rich; I'll try that. Best wishes.
rich912
Contributor
You're welcome editorbeemac.
I should have mentioned that you could access details for your model by entering the serial number in the following link.
http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
