Dear Vaio user,
I need some help, pleae. Just bought a new RC202 Vaio and, amongst the many issues to be solved, I cannot see anything when connecting the DVI output from the GForce6600 to the DVI input of my HD TV. If I instead use the VGA output into the same DVI input on the TV it works fine.
Can some one help?
P.S. As I have noticed in other post, I too have problems to get a decent video picture when connecting a Sky box to the PC (low VSH like quality and 4:3 ratio or even smaller)...that's for tomorrow.
thanks
