Installing Programs
djwoody
Visitor
Installing Programs
I have recently formatted my Vaio FE21H and installed XP Pro on it.
I am wanting to install Roxio CD Burning software that came with my laptop and is on my backup disc.
Before i formatted, when you insert this backup disc it would pop up with a window asking you which programs you would like to install.
Now, this does not pop up and when i look in the CD it just has files in folders (APR, APR1 etc) and no installation files for the apps.
How can i install individual software from this disc?
Chris
5 REPLIES 5
profile.country.en_GB.title
kee-lo_
Member
Have you installed all the VAIO utilities and hotkeys from www.vaio-link.com? This is happening because your DVD doesn't believe your VAIO is a VAIO.
djwoody
Visitor
I don't want to install all the utilities, which are the ones that are necessary for hotkeys etc...
djwoody
Visitor
Does anyone know which ones i need to install???
kee-lo_
Member
I think they're all in utils.exe now
djwoody
Visitor
I have installed all those utilities and still no luck.
Is there a recovery program i need to install?
