hi all.
Does anyone know if you can get a car adapter for a vaio grz615s. so it would either charge the battery or run the laptop from cigerate lighter ?
Thanks from gav
hi all
Well i found a universal one but they arent cheap
its 57 quid,
far to much for a poxy incar charger
If you go to PC world you can buy an adaptor called "AC Anywhere" which plugs into your 12v cigarette lighter in the car but produces regular AC power via a 13amp square pin outlet on the adaptor. You can use it for any low powered item such as mobile phones or laptops. Works great!! Cost? £60.
Or do a Google for "in-car inverter" - should be able to find something cheaper than £60:smileylaugh:
Edit: Here's one I found with a quick search:
http://www.time2talk.co.uk/pr-Car-PC-Inverter-140W.html
