How to open PCG-7T1M for replacing the power socket for the PSU
tony2912003
Visitor
Hi, I've taken all the screws off and the front facia with the keyboard is ready to be removed but there is something holding it back. It looks like a screw
about where the position of the F6 key is.
However, there is nothing that I can see to access such a screw.
Any ideas would be appreciated.
Thank.
crb_london@yahoo.com
4 REPLIES 4
Blencogo
Hi Tony and welcome to club Vaio.
You are quoting the chassis number - I assume you have a N-Series Vaio (VGN-Nxxx), look for the correct model type on the screen surround.
If you confirm the model type is a N-Series I will send a copy of the Manual by email.
tony2912003
Visitor
Thanks for the update and the pictures.
The Model is PCG-7T1M and my email is crb_london@yahoo.com
Thanks.
Blencogo
N-Series Manual sent.
I think you have a VGN-N11S.
:wink:
tony2912003
Visitor
Oops, you're right.
That's what I meant to post - sorry.
Thanks for all your help. The problem is now sorted.
That last screw was under the keyboard, so the keyboard had to be removed to access it.
Cheers.
