Solved! Go to Solution.
Try this: -
1. Click the "Start" button, type folder options and click the "Folder Options" link that appears.
2. When the "Folder Options" multi-tabbed dialog box appears, click the "View" tab.
3. Uncheck "Always show icons, never thumbnails" to enable thumbnail generation.
4. Click "OK" to close the dialog box.
If you click on 'VIEW' in the top menu bar, do you have the option to choose Thumbnails rather than Icons?
Also make sure the folders are designated as picture folders. View -> Customise this folder -> choose Pictures as the folder type from the dropdown box.
Thanks for advice.
Alas, I'd tried those.
The 'View' options are the usual - Icon size, List, Details, Tiles, & Content.
The Customisation is set to Pictures.
Trying the 'Rest to Default' has no effect either.
Try this: -
Halleluya!
Great Blencogo. That's done it.
I suspected there was a relatively simple solution, but I sure didn't know of this window.
Thanks a lot.:smileyhappy:
