Hi
I hope someone can help me.
My almost new Sony Vaio VPCEB3F4E is having intermittent problems connecting to my wireless router.
My ipad and iphone have no problems. I can surf on the ipday whilst simultaneously not be able to connect using my laptop.
Router therefore looks fine.
All of a sudden will then work again. Is this a driver problem or wifi interference?
I ended up switching off all other wifi devices this morning after struggling for a while and then hey presto back to normal.
This isnt really a satifactory solution.
If you can help me that would be great!!
Thanks a lot
Sam
