HD knocking noise
Murdoc83
Visitor
HD knocking noise
So when you have problems with this knocking noise of the HD you need to go to sony to repair it?
Opening up the laptop and doing it yourself will mean you lose warranty?
9 REPLIES 9
profile.country.en_GB.title
robpaxton
Explorer
If you dismantle the notebook then (if they can tell) your warranty will be invalid.
Some models of hard disk do make a tapping noise and this doesn't necessarily indicate a fault.
GattoMatto
Visitor
Why should you do it by yourself if your laptop is still under warranty?
Murdoc83
Visitor
Not having to miss my laptop for i guess 2 weeks....
kee-lo_
Member
Rob's right, this might be it's usual operating sound
Murdoc83
Visitor
It's just a single short knock and it's frequence varies but it's quite hard...
kee-lo_
Member
Sounds like parking to me
amj.designs
Visitor
i have had 4 laptops in the past this is my first sony and they all have done this nose espacially when you are going through your files so i think you should just accept it thats what you will have to put up with.if still worried why don't you open an e-support to see what they say?
jumpsuit
It could be a small Sony engineer stuck inside the casing?
kee-lo_
Member
LOL I doubt that, they'd sufficate in that heat!
