Grey border around desktop icons
FranzH
Visitor
This probably has a really simple answer but ive looked on google to try and fix this but i cant find anything. Heres the problem: i was messing around on the desktop just moving things etc and then the icons just had a grey border around them they stayed after turning off the pc and its really bugging me.
10 REPLIES 10
rich912
Contributor
Not entirely sure what the problem is here Franz, but I would suggest that you carry out a system restore back to a date before the problem occurred. (Start > All Programs > Accessories > System Tools > System Restore).
Go n-éirí an bóthar leat
FranzH
Visitor
Good idea :slight_smile: thanks
FranzH
Visitor
You know on the calendar... only todays date and yesterdays date is in bold
rich912
Contributor
In that case I suggest that you scan your system for viruses/malware!
FranzH
Visitor
Ok so what do you suggest next about the grey icons? Is there like a default button for all icons?
rich912
Contributor
Have you scanned for viruses/malware?
FranzH
Visitor
Doing it now - Spywear Doctor + Spy Bot.
I might run that trend micro house call one over night
rich912
Contributor
Also carry out a full virus scan.
FranzH
Visitor
Ok shal i post back here when they are all done?
