Connect Player 1.0
RubenBCN
Visitor
Connect Player 1.0
Well, it seems the new Sony Connect Player is crap.
http://www.atraclife.com/index.php?showtopic=412
Anyway, here you have an update:
http://www.sonydigital-link.com/DNA/ConnectPlayer/Update/Update.asp?l=en&ul=en
Anyway, I'd like to try it in another computer (not mine) so anyone knows if the software can be downloaded from any website?
Thanks.
1 REPLY 1
Pete00000
Visitor
Thanks.
After talking to sony (I have mislaid my disk) it seems that the only way to get another copy is to order it through sony for about £8.50 (expensive for some buggy software).
It is not free like sonic stage and is limited and therefore not sold in shops.
