FZ21M BD/DVD DRIVE ISSUES
sashak87
Visitor
Hi
Have got a FZ-21M with a blue ray drive and I'm having trouble playing dvds. On the 'my computer' screen it shows 2 cd drives, one called F which is a BD drive and one called I which is a CD drive. However this is wrong as i only have one disc slot whoch is a BD/DVD/CD combo drive. It never used to show up like this before and since it has started I can no longer play dvds or cds.
I cant find the device drivers anywhere, I've tried uninstalling them both but it just auto installs them back the same way.
Any ideas???
Thanks
2 REPLIES 2
Blencogo
Hi sashak87 and welcome to Club Vaio.
What version of WinDVD BD do you have installed? You should have WinDVD BD 8.0.9.429.
There is a firmware update for the BD-Combo Drive UJ-120B version 1.03080107 if you have this model fitted.
I have not heard of two drives appearing in My Computer - are you sure one of them is not a Memory Stick or a SD card drive? I would phone Sony with this problem as it is a new one on me.
Not wishing to be a pessimist but many users here have given up on WinDVD and converted to PowerDVD Ultra to save a lot of hassle.
:thinking:
sashak87
Visitor
i've downloaded all the updates i can from the update site. On device manager it comes up with 2 cd drives called:
Matshita BD-CMD UJ-120 ATA device and
WB6230R VGQ381P SCSI CdRom device
the second one sounds like it shouldnt be there.
Any ideas? I'll try giving Sony a call later. Where can i download PowerDVD Ultra from?
Thanks
