Hi
Does anyone know where I can find the drivers to make the function keys work onn XP Pro on my Sony VAIO VGN-FS295VP Model PCG-7A1M?
I cannot adjust the screen brightness and it is too dim. Also I cannot adjust the sound. Basically the blue function keys do not work and I have installed all the correct drivers? I have seen this talked about when upgrading to viata but I am using XP.
This is so bad it is causing me eye strain.
Thanks
Mark
Hi Mark and welcome.
Go to the Support Downloads Page for your Vaio here: -
http://www.sony.co.uk/support/en/product/VGN-FS295VP/updates
Under the Preinstalled Drivers and Utilities Tab, download the Original Utilities Package.
The file will download as a .ZIP file. Right-click on it and choose 'Extract All'. Choose to extract to C:\
For the Fn Keys install: -
1. Utils Installer 1 (Sony Utilities DLL)
2. Utils Installer 2 (Sony Shared Library)
3. Utils Installer 6 (Setting Utility Series)
4. Utils Installer 7 (Vaio Event Service)
Install these in order and, if necessary, be prepared to install them twice.
