Capture Button Not Working - CR31S/L ???
kenyon1
Visitor
Hi everyone
The capture button on my sony laptop - cr31s/l is not working. Can someone tell me what the botton should do when pressed. I have been into the sony camera capture utility, and pressed the capture button located to the top of the notebook, but it does not take a picture.
any help??? thanks.
6 REPLIES 6
Thalamus.
Champion
Hi Kenyon1,
the Capture Button should launch the Vaio capture utility..
see attached excerpt from the manual..
kenyon1
Visitor
No it dosn't. What shall I do?
Thalamus.
Champion
Do you get any error messages.?
Does the Vaio capture utility run if you launch it via Start > All programs.?
kenyon1
Visitor
Yes, the vaio capture utility does start when i load it via all programs. No, no error messages appear on screen. All the other buttons work, its only the CAPTURE button that dosn't work.
any help would be great, or is it going to be a call to sony?????
Thanks
kenyon1
Visitor
what shall i do???
kenyon1
Visitor
What shall I do, how do i re-program the button??
