Battery life
JohnE
Visitor
Battery life
Hello friends.
Iam new laptop user.I have destop computer many years but laptop just now have.i have one question about battery.if the laptop use in my house is better to use it with out the battery on in my laptop or must be on .:smileythinking:
3 REPLIES 3
gigierk
Explorer
If you wont use it without the AC Adapter you can run it without the Batterypack. I have heard that you can extent the life of the battery when you store it in the fridge.
JohnE
Visitor
thanks friend:smileyhappy:
Thalamus.
Champion
Hmmm, not heard that before!
For best results, keep the battery cool and store the battery at a 40 percent charge level. Never fully charge or discharge the battery before storage. The 40 percent charge assures a stable condition even if self-discharge robs some of the battery's energy. Most battery manufacturers store Li-ion batteries at 15°C (59°F) and at 40 percent charge. (extract taken from If I remove the battery & run from a power source will it lengthen battery life?)
