hi,
i have a sony Bravia with a Netflix button which used to take me directly to Netflix app. Now it doesn't work And I have to access Netflix via apps so Netflix itself is working. Note quite sure how and why this happened but I have a 19 month old who likes playing with remotes so she may have done something to knock it off!!!! Any ideas on how to reset or fix???
thanks
Solved! Go to Solution.
I had the same.
Went to network settings (?) and did an update Internet content. All seems ok now.
I had the same.
