I want to buy a sound bar for the above TV and need a recommendation. Can I go wireless to this TV or if not, which connection on the TV do I use. This is to make sure I have the right connection plug and cables etc. What do you recommend as the best sound bar for my TV.
Thanks Chris Pearcy.
Hi, could you double check the model please? You can also check this link here for the Bluetooth compatible TVs and soundbars: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-55x8509c/artic...
