No Picture on Bravia 22X20D
profile.country.en_GB.title
wyn.thomas
Visitor
My Bravia 22X20D has developed a fault whereby the screen is black with no picture or menus visible despite the sound being present. Menus are dimly visible if the screen is lit by a torch. This fault developed suddenly, the set is about fifteen months old.
1 REPLY 1
Bravia55HX
Member
Hi,
it sounds like a backlight failure, i would suggest you contact your dealer or your nearest Sony authorised repair centre.
