KDL-32we613 scene selection
SOLVED
gersy555
New
Hello,
I recently got a second-hand kdl-32we613 which works very well. However, I can't find how to manually set the scene. The manuals I found online mention to press the "options" button, but there's no such button in my remote controller (RMT-TX100D). Any idea on how to fix that?
I also observed there's a lot of reflection in dark scenes, any suggestions on how to set it so that dark scenes are viewed better?
Thank you!
1 ACCEPTED SOLUTION
Accepted Solutions
Hi gersy555,
This is not the correct remote for this TV.
The correct remote model would be the RMT-TX300E.
With this remote you would find the options button here:
Screenshot_2020-08-10 ALLIMITY RMT-TX300E Remote Control Replace for Sony Amazon co uk Electronics(1).png
A replacement for the original can be found on e.g. Amazon:
https://www.amazon.co.uk/dp/B07BMYFFMD
Cheers
Peter
2 REPLIES 2
Hi gersy555,
Cheers
Peter
gersy555
New
Hi Peter,
Many thanks! Now it makes some more sense, I already bought the replacement controller!
And do you have any hint or suggested configuration for the glares with dark scenes?
