Hi all,
I have the following questions which some kind souls may be able to help me with my first post...
* How do i delete photos and ringtones from my X10i?
My phone is going well and can't understand why so many negative posts..
Merry Xmas to all 🙂
Solved! Go to Solution.
When viewing your photos in Mediascape, press Menu and one of the options will be delete.
You can also download Astro file manager free from the market and use this to find files on your SD card and then press menu and edit and delete is one of your options there. You can also use the multi tool on it to delete more than one at a time, or indeed move/copy/paste etc.
On the ringtones are they ones you have downloaded... if they are you can use Astro to locate them on your SD card I have some in sdcard/media/audio/notifications. If they are system ones, I'm not sure where they 'live' but have a search around on your SD card using Astro.
Hope it helps.
Hope it helps.
Just had a quick look with Astro, you need to press Home then Up and then find the system file then its audio>ringtones and I think you can delete them from there.
Glad you are sorted!
If you run into anything else that you need clarification on just shout out on here and hopefully someone can point you in right direction.
Can I shout too ???? :smileymischief:
No you can't, lol. You are one of the ones that I am hoping will carry on giving out the good advice! :smileygrin:
I wish to too, kind of luving it. By the way, it has become sort of a habit already (habits are hard to kick). Sad to say, I am still not as good as someone (the one who is going to reply me).
Message was edited by: gwhispererz Since she did not reply, I shall amend my last sentence to 'the moderator here'.
