Receiving SMS doesn't work
OPGELOST
Niet van toepassing
I have updated my phone (X10 mini pro) to latest update (build 2.1.1.A.0.6), and I have stopped receiving SMS. I can send SMS, and I can recive calls and call others.
I put different SIM cards into the phone - same thing. Put those SIM cards in another phone - they work.
Any ideas?
Is there a way to revert to old build before the update?
Thanks
1 GEACCEPTEERDE OPLOSSING
Geaccepteerde oplossingen
Uliwooly
backup everything but the settings
then repair your firmware/software with either PC Companion or Update Service
Bekijk de oplossing in de community in het oorspronkelijke bericht
3 ANTWOORDEN 3
Uliwooly
Niet van toepassing
Thanks, that worked!
I expected it had something to do with the update itself. Slightly_smiling_Face
Uliwooly
I'm glad it worked out for you
