Problems after updating x10 mini pro
SOLVED
Not applicable
Hi
I just bought my SE x10 mini pro, and today i said that there was some firmware updates for it.
then i updated the phone through pc companion and followed the screen, and after a while the phone was updated.
BUT then my problem started, I have some source code / text running in the upper right corner of my phone screen all the time.
every time i'm starting a new program or returning to home screen I can see the commands the phone is giving.
how do I get rid of it ?
hope you can help me
Message was edited by: MrChaos Took a picture so you can see what I meen Slightly_smiling_Face
1 ACCEPTED SOLUTION
Accepted Solutions
suze
Leader
I'm wondering if you should try a repair via either PC Companion or Sony Ericsson Update Service.  This will reset your phone so you will lose data stored in your phone memory (sd card should be fine) you need to back up your contacts to either the SD card or sync.  Any apps you have downloaded you can reinstall from the market afterwards.
3 REPLIES 3
suze
Leader
Not applicable
Hi.
I tried to do like you said, and it did work perfectly for me, thanks for the help Slightly_smiling_Face
suze
Leader
Well done on getting it sorted.  Glad to be of service:smileywink:
