Hi guys! I have my Xperia... I love my X10!!!! but now with the new sw 2.1 when Im trying to send more than 1 txt at the same time Im having a box saying Could Not Send... I have the problem only when my txt is long at is converted to 2 sms... Can u please help me to know what is going on??
Thanks in advance for your help!!!
LEO
Solved! Go to Solution.
this is a bug that most X10 users, including myself, are experiencing
Some had been able to get rid of this by going to
Settings
wireless & networks
Mobile networks
Network mode
GSM only
There seems to be another thing that trigger it, if you have a LOT of texts in your messaging app, it will give you that error.
Thank you so much!!! Is working now... This new configuration on the network does change something else? Any other thing is being affected?
THANKS AGAIN!!!
it all depend on who is your carrier, for most people it does not affect their 3G or H coverage, for others it does affect that and they only receive 2G or G.
an easy way to check for that, on the top next to the bars, what letter and number do you see?
Some users have this issue, just like uliwooly is saying.
We're investigating this to find out why some have this and also of course why not all users have this issue.
Some users have been able to solve the issue by doing a factory reset of their phone. I can't confirm that this is a fully working solution since I've never had this issue myself - but please, feel free to try this. If you do, I'd love to get some feedback on the result.
You can do this at Settings > Privacy > Factory data reset.
Use handcent...SE seems to be really good at messing up things that work great for everyone else
and remember the more SMS/MMS you have stored in your phone, the more often this will happen
