does stopping the apps from settings>apps>running cause a problem
SOLVED
sanky
Visitor
i am an user of xperia p
i had a new "xperia p" last month today i noticed tht the running apps is utilizing more spzce of ram (which can be found in settings>apps>running)
so i stopped some of the apps like subway reun, goole maps and more 5 apps i didnt even remember their names
does stopping of such apps will cause me a problem in any kind while usage of my phone
n plzzzz do suggest me that which apps should be stopped from running n  which should not !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
guysss plzzz do rplyy!!!!!!!!!!!!!!!!!!!!!!
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
you shouldn't stop them, there's a reason why they are running but if you don't use those apps just uninstall them or disable them
settings > apps > all > look for the app > disable/uninstall it
do NOT use any taskiller, antivirus, task manager
Don't forget to mark the Correct Answers & Helpful Answers
6 REPLIES 6
Uliwooly
RubinOwnz
Visitor
yeah man, task killers basically kill your phone :smileysilly:. As Uliwooly said, disable what you don't use, and don't stop services like homescreen or settings and stuff you use every second. Try restarting your phone, and see what services are on. Don't stop those services. Everything else you can stop it without a problem.
sanky
Visitor
thnx for ur rply !!!!!!!
sanky
Visitor
thx for ur rply !!!!!!!!!!!!!!!!!!!!
sanky
Visitor
but how could i save the sapce in my ram the apps i use are all of use to me !!!!!!!!!!!
so can any 1 of thm can suggest me something !!!!!!!!!!!!!
RubinOwnz
Visitor
as long as you use everything, you don't have what space to save. basically xperia p has 1 gb ram, from that you are left with 450-500 (max) usable. Ram it's made to be used, so don't worry about it. All you need it's like 150 mb free when you use the phone regularly, and it won't lag. My current free ram it's about 320 mb.
Btw, when you stop apps like Google Maps and such, they will automatically start again. If you don't use them, disable them.
