Vibrations
SOLVED
Sipho1120
Visitor
Vibrations
Hi just need some clarity on something. It's it possible to to have my M4 vibrate when receiving calls and texts whilst my phone is on stamina mode?
If I have to go to battery optimisation to make it happen which apps do I select?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
Emil
Enthusiast
Hi @Sipho1120,
There is no such setting. If you put your device in STAMINA mode your phones vibration will be disabled.
Let me know if there is anything else you are wondering about.
2 REPLIES 2
Emil
Enthusiast
Hi @Sipho1120,
Sipho1120
Visitor
Hi, once realised some advice from you which was very helpful. Please help once again. "Unfortunately camera has stopped" keeps on poping up whenever I try to activate my camera. I've already tried restarting and going back to factory setting but im still encountering the same problem. Please help.
