how to swap phone internal memory to external memory
SOLVED
Som6
Visitor
Is it possible to swap internal and external memory in xperia m dual?
If yes then how?
1 ACCEPTED SOLUTION
Accepted Solutions
Uliwooly
I don't quite understand your question, but you will have to root your phone > partition your SD card > and you might be able to use it for your apps and games
5 REPLIES 5
Uliwooly
Som6
Visitor
Will it violate warranty period/terms?
Tags (1)
Uliwooly
it "could" void your warranty
betulin
Visitor
Hi, i would like to swap internal to external memory. My device is rooted. Could you tell me it is possble and how to do it.
Thanks
Xperia M c1905 sd car 32 gb 10
Uliwooly
@Betulin you can't, you could root your phone > partition your SD card and use an app2sd app
