Heating issues of xperia m4 aqua dual
9537044636
Visitor
Give us justice... From heating issues of xperia m4 aqua dual..... If we do browsing or gaming it will be heating up to 50 degee selc. And at this time camera and some other apps cant open or work properly...
So what can we do.? Give us new mobile orrr repair it...
13 REPLIES 13
Shen02
Visitor
@Good9
You must format your device after update firmware or android..
to reduce the heating & battery drain just install
Greenify from play store this app also improve
your battery life.
AJ0807
Visitor
I'm using Xperia m4 aqua, and have heating issues
profile.country.US.title
Qatrium
Hello @AJ0807
If this issue is too much to handle, or if you have excessive battery drain or lag along with it, then I'd suggest that you do a software repair using Xperia Companion. This will do a clean installation of the latest firmware and will also wipe your internal memory. Follow the steps given in the blue link, do not connect your phone until prompted to press volume down while plugging USB cable.
Don't forget to backup using Xperia Companion before you perform the repair process, but don't backup apps or settings.
nftj6
Visitor
i have a possible slution 1.the problem cused by the msm8939 chip that heat up match 2. to fix that you need to be rooted then download no frils cpu from play store then lower cpu speed and set profile to power saving and applay then reboot     note: 1.do this at your own risk  2.this will slow your phone a bit but remember your phone dosent restart or heat up match  if you dont want this methoud you have to update the phone to the latest vertion with flash tool if nothing fixed you have to replase the motherboard soory for my  bad english
