HDR UDP-X700
Feynman2
New
HDR UDP-X700
I have LG oled55b7v
using sony up-x700 .  Will not show HDR at 60p
display always shows SDR 24p
1 REPLY 1
Sean_Mc
Hi Feynman2,
Welcome to the Sony Community.
Can you make sure the HDR output is set to "Auto" from Home - Settings and Adjustments - Screen settings. Also, make sure to adjust the settings on the TV and that the content you're watching is HDR.
Hope this helps!
Best wishes,
Sean Mc
