Speakers for Sony LBT-V702 Separates?
SOLVED
BigNabz
New
Hello, I recently acquired a set of Sony LBT-V702 separates without the speakers, I'm keen to set it up and I was wondering if anyone knows which set of speakers goes with them?
Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
IamNic
Hello @BigNabz,
as it has normal speaker cable clamps on the back you just need to study the manual to find out the resistance the speakers need to have (4 or 8 Ohms) - if you know that you can freely choose your speakers to use with the system.
- Nic
3 REPLIES 3
IamNic
Hello @BigNabz,
- Nic
HannahEd01
Hi BigNabz , I couldn't find the model anywhere on the Sony website, are you sure it's correct??
IamNic
Hello @HannahEd01,
it is a veeeery old model and therefore not listed on the Sony website. Check ebay and other marketplaces and you will find the system being listed there.
- Nic
